big hint: DO use anti-seize compound on ALL threads on ext systems and all the other threads on the bottom of the truck. and do NOT use cad plate bolts on ext systems. the heat will make the cad plate come loose and jam the threads. and any chryslers that have flange to flange connections do use the largest bolt that fit. a under size bolt will get loose.
