Dan the man
What is the best fitting headers for a "A" body? 318 with a 904 transmission. Mufflers? I'm not looking for the glass pack sound, wanting the best performance from the exhaust system.
No clue what you're talking about? Everything looks normal with replies, dates, and see no arrow.Why does my post have the amount of replies and when it was posted removed? Also why is there a arrow pointing to the right? Simple explanation or what?
Under normal threads my post EXHAUST doesn't show how many replies there are, the date I posted it is goneNo clue what you're talking about? Everything looks normal with replies, dates, and see no arrow.
Turn your phone sidewaysUnder normal threads my post EXHAUST doesn't show how many replies there are, the date I posted it is gone
Don't know why it shows that on your end but it shows all of that info on mine. That said, I do view the forum on my PC.Under normal threads my post EXHAUST doesn't show how many replies there are, the date I posted it is gone
K. I remember you saying that before. Guess I have crsTurn your phone sideways
Thanks for checking that out. My phone isn't the greatestDon't know why it shows that on your end but it shows all of that info on mine. That said, I do view the forum on my PC.
I put a full-length dual 3"inch system on my car, with dynomax Muffs; no complaintsWhat is the best fitting headers for a "A" body? 318 with a 904 transmission. Mufflers? I'm not looking for the glass pack sound, wanting the best performance from the exhaust system.
Don’t buy the headers that go around the steering linkage on the drivers side. Will get smashed flat on the first big bump. I have a set for sale I took off my car. Some assembly required……
I'm going to run midlength headers so I won't have that problem.^^^ This. Low headers are no fun... this is what low headers get you.. the dimple at the very front was made trying to get my heap on an alignment rack.
Oh... and mine came out the same way.... lol.
Wouldn't 3" exhaust be over kill for my application? 2 1/4" is just about right, 1 1/2" primary tube headers with the 2 1/4" exhaust system will scavenge the combustion chamber not only faster but more complete, doing this greatly reduces the chances of contaminating the fresh fuel mixture entering into the combustion chamber. I may have to use 1 5/8" primary tube headers. For the rpm range that my engine will be operating in I don't need big tube headers. Midlength headers may cost some low end torque from the research I've done and people that I've talked to. Is this correct or not?I put a full-length dual 3"inch system on my car, with dynomax Muffs; no complaints
I don't know how to weld and I'm not going to pay to have a set of headers made.^^^ This. Low headers are no fun... this is what low headers get you.. the dimple at the very front was made trying to get my heap on an alignment rack.
1974 dart. No power steering. Budget? I know that a quality headers that are ceramic coated are not cheap but Hopefully it will be a one time purchaseWhat year?
Power steering?
Budget?
Price point, Patriots fit good on some, but like most,they hang down.
TTI or Doug's are expensive but perform well and fit good too.
What's wrong with midlength headers? They are good for torque and I won't have to worry about dragging long tube headersMid length headers?
Longer the tube, the more torque is made.What's wrong with midlength headers? They are good for torque and I won't have to worry about dragging long tube headers
