factory 383 A body throttle cable housing length...
Just removed an original from a 67 Dart GTS convertible, but I do not know if it would be the same since it was on an AFB instead of an AVS and of course the lower performance intake. The other one I thought was original is a repop after I examined it closer.
LENGTH OF HOUSING SHOULD BE THE SAME ON 67 [CABLE INSIDE MAY BE A LITTLE SHORTER OR LONGER] AS THE INTAKE MANIFOLD BRACKET IS THE SAME 67-9 AND MOUNTED IN THE SAME PLACE...
OK, I left it at the shop, will get it on Thursday which is the next time I am out there.
I took these pics today...
i have had one measure but a second would be great to verify for sure... thanks
SO FAR NOBODY CAN HELP IT SEEMS... JUST NEED MEASUREMEMT FROM FIREWALL TO END OF HOUSING [JUST TO WHERE CABLE COMES OUT TO HOOK TO CARB] OFF 383 A BODY 68-9...
I think it's 17 inches I have one out on loan right now.
What's wrong with post 21 ?
That is the length you're looking for
JUST WANT TO BE DOUBLE SURE... MANY HAVE BEEN REPLACED AND PEOPLE MAY NOT KNOW... WHY I ASKED TAHT ONLY KNOWN ORIGINALS BE MEASURED THANKS
