Mike P 52
Active Member
Real quick (and probably stupid) question. Did Chrysler produce a factory AC for the 68 Valiant or or were they all dealer installed units? Is there a later factory Heater/AC unit that will fit?
Yes there was factory installed a/c but there are several reasons why you don't want it, especially in a build that didn't come with it.Real quick (and probably stupid) question. Did Chrysler produce a factory AC for the 68 Valiant or or were they all dealer installed units? Is there a later factory Heater/AC unit that will fit?
The under dash unit dubbed "knee knocker" has its blower built in. Only mod to the firewall is holes for the 2 freon tubes and a condensation drain.Thanks guys. I'm just looking at options right now and appreciate the info.
I'm turning a former street/strip car (more strip than street) into a daily driver and still collecting parts/information. I live in AZ and where I’m at heat and AC are mandatory.
Thanks to your info it looks like I’ll have three options.
Factory AC/heater if I can find good donor.
An aftermarket heat/AC unit.
Stock Heater and under dash AC (kind of leaning this way if there’s room for the blower motor on the engine side of the firewall)
Again thanks.
And 2 holes in the floor for evaporator drain.The under dash unit dubbed "knee knocker" has its blower built in. Only mod to the firewall is holes for the 2 freon tubes.
You are still a cut above the OEM push button a/c controller that was always trouble.I have a dealer installed "Knee Knocker". I wish I had a new aftermarket set up with a lightweight compressor and in dash unit.
That’s what I will be using in my 47 Dodge sedanThe under dash unit dubbed "knee knocker" has its blower built in. Only mod to the firewall is holes for the 2 freon tubes and a condensation drain.
Many many years ago I found an original Mark IV under dash unit in a 60 Chrysler in a junk yard and bought it. I did a cosmetic restoration and painted the case interior color. It has a beautiful chromed metal face and vents and a little thermometer in the center of it.
View attachment 171612333457 Int[/url] by https://www.flickr.com/photos/153889607@N08/]M Patterson[/url], on Flickr
It found a home in my 57 Plymouth and even converted to 134a it will freeze you out (at least in the front seats LOL).
No such thing here. When you are looking for a answer that's what we are here for.Real quick (and probably stupid) question.
