dibbons
The rocker shaft (on top in fotos) I borrowed that had used springs for spacers instead of the more common rings has a different oil hole orientation when compared to the hold down bolts. The hole diameter is obviously much larger as well. A previous owner could have enlarged the holes (doubtful) but the different orientation was a factory change/update for sure. Never have seen this discussed on a forum before.
