in my case is that the top or bottom thank uThe jumper goes between the two terminals of the ballast that your coil wire runs off of.
Note the notch on the end of the four wire ballast, do it like this and it should be right.
The picture is right off of the FBO website.
when i hook it up what do i do with the old wires?The jumper goes between the two terminals of the ballast that your coil wire runs off of.
wb the jumper im putting the new modjel on in the morningby the looks of it nothing...just plug your old wires back on...
do you have a picture i want to do this job quick hook up the fbo rev limtier ecu and coil an jumper An goWhy the jumper, just remove the guts and solder in a piece of 10g wire. That's what I did, nobody knows from the outside !
really doesnt make sence i just want to hook up and go i dont know if the jumper goes on top or bottom and where the wires go??
o ok on the gold new gold piggy where the jumper ties in thank you thats what i was woundering!The wires go back on the piggyback blades of the jumper just like they were.
Look at the picture I posted again and note the note about which end has the notch in it and put the jumper on accordingly.
do they work good this is my first one and am excited to take off the chorme box and a 25 year old coil lol
