fifth avenue small block?
74slnt6
Canton, Ohio
ok, so i got a fifth avenue for a winter car. I wanted to know what headers any of you recommend. I just want some good clearence, and some better sound. any ideas?
just about any a-body header will fit. tti's having the best fit. just depends how much you want to spend.
What year 5th Avenue? It is probably a roller cam motor with #302 casting heads. Save those babys!! toolmanmike
its a 87 with a roller... i dont know about the heads, would they be 302 heads if it has a roller?
Regular steel headers will just rust out if driven in the winter. If you do go headers, go with some stainless steel ones. I'd stick with the stock manifolds and have a custom shop make you some true duals with some Dynomax turbo mufflers.
