My beater with a heater, and now I know why it takes so long to warm up the cab (Tooljunkie), and some spares just in case.
View attachment 1715416122 View attachment 1715416123 View attachment 1715416124 View attachment 1715416125
As awesome as it is, the real kicker is the early model 1972 360 truck block. The camper special brakes are usually different than the standard brakes. The best fix is to find a set of spindles and caliper mounts from a 72-93 D200-D350 with discs and upgrade to the D or W 350 large tank master cylinder. The control arms are all interchangeable except the heavy duty trucks have larger ball joints.
I still got quite a few parts left over from the 72 2-wheel drive apart it out last year so if you're needing something make sure you say something...That's my plan, hopefully it warms up around here by Saturday so I can hit the junkyard. It has mostly 80s-90s-early 2000s stuff but I always see at least a couple older Dodge trucks every time I go. Lots of B-vans too.
I was wondering about it being an early truck 360 as well, that would be awesome if it has the thick cylinder walls. It's definitely never been apart as far as I can tell and was maintained well.
Also curious, this truck has true dual exhaust routed side-by-side down the passenger side; is this a factory-type setup or did someone upgrade it at some point?
They all had tank in cab, Ford stopped in I think 77ish. Fumes with today's gas would be my concern. Nice truck, have fun finding all the "Farmer Fixes", I swear its a old truck right of passage to have something poorly rigged.
Cool trucks. Don’t see many of those 4 headlight front ends, a 79 I assume.
For a van...I'm look'n at CL everyday..... and hoping....![]()
Yes, a Van. But if I found a solid 70's era 1/2 ton truck that was reasonably priced....For a van......
I'm not on FB, and when I tried you had to have an "app" to see it?I actually found mine on FB marketplace, it's gotten really big with this kind of stuff.
Regarding a tune-up the ignition still uses breaker points, I was hoping to see the electronic ign. unit but noope. I'm thinking of putting a PerTronix module and coil in it? Of course along with new cap, rotor, plugs, wires. This thing is really stock aside from the exhaust, but in really good shape it never even made a lifter tick when I first got it started. I'm curious about the power (and everything else) I want to drive it so badly.
Nice score. Ya get rid of the in cab tank. My 78 had one. My 79 and 80 didn't. Your saddle tanks is probably 28 gal.
I have a 73 that my dad bought new. Also get rid of that crappy Holley 2-bbl and install a good 4-bbl. You'll have some more power and a couple more mpg.
If your area is anything like my area, you’d be doing yourself a BIG favor my getting on FB. I still check CL from time to time but it’s gone down hill big time for vehicles and car parts. Everyone’s switching to marketplace. You can also search specific areas much easier on marketplace as well.I'm not on FB, and when I tried you had to have an "app" to see it?
1973 dodge d100 stepsideCongrats on the truck, Khalid!! I personally would LOVE to have a 74-76 D100 stepside, like the Mopar Muscle Truck.
Nope sold it...You still have the rear axle?
