nates68
Installed the kb362 pistons into stock deck height magnum 360. Came out to zero deck! Now just need the heads to get it buttoned up.
Nates68
Nates68
Here's a dash pic, just need to decide on gauges. Decisions....
I like the sewing on the pads, nice. Here is what I did for gauges and radio. They are actually custom "restored" by Redline gauge. The tach is aftermarket with custom stencil from Redline with the rev limit set where I asked, speedo is refaced and calibrated, ammeter converted to voltmeter, fuel gauge swapped to one that works with my aftermarket tank / sender, and the instrument voltage regulator (IVR) has been swapped to solid state. Radio is aftermarket AM/FM with aux input, 4x40W, and amp pre-outs. You are ahead of me on dash pads, mine will be similar to yours.
If you used the yellow contact cement that comes in a metal can. Quart paint can not the aerosol type.
It will hold up and remain stable for many decades as long as it doesn't get wet. It does cure and is unaffected by heat.
If you used the aerosol spray trim adhesive it is formulated to never cure giving it the needed shelf life and ability to to be sprayed from the cans nozzle. Good marketable product but bad for a trim project that is subjected to heat. Particularly when gravity is opposing it remaining in place.
You should be OK on your dash pad if you used the aerosol trim adhesive as it is wrapped and clamped after being bolted in place. It can blister if it gets very hot due to the non cure formula though and may need to be repeatedly pressed back down flat.
Your work on the pad turned out great and you are remarkably skilled to get such results on your first dash. I am quite impressed. The A body pad is an easy one but I know how difficult dashes can be. As the owner of an upholstery shop. I have never been able to teach dash pads to employee's with good results.
Just as impressive is the styling and execution fabing up the rear spoiler. Like it a lot. All barracudas should have came with them from the factory.
You got this car building art form mastered.
View attachment 1714958512 Ended up
Had the car out in the driveway to spin it around for motor install, had to take a pic!
Nates68
We want more pics! That's one pretty car!
So the dash pad you just reupholstered yourself? If you have more pics of that send them to meThe dash pads were a lot of work! My concern is if the contact cement holds up over time.
Keeping my focus on the drivetrain, would like to have it move under it's own power this year. Still deciding on fitech efi or real nice carb.
Nates68
car is kick a$$ ! except the wheels LOLView attachment 1714958584 Another one
Na na na na, its the other way around!car is kick a$$ ! except the wheels LOL
