Frank Mopar
I purchased on of www.classichei.com ignition set ups for my 360 sb. Just had to get rid of that fussy ballast resistor. For $100 this thing is awesome. I ordered it on a fri and it was at my house on mon. A tech question was answered the same day so kudos to classic hei for the prompt service.
Easy to hook up. Two wires hook to the dizzy and the old coil + wire goes to the new coil. You bypass the ballast and fire it up. I had a ballast that I was able to take apart and replaced the resistor with a 14 wire so it looks like it is still hooked up. Open up the plugs to .045, check the timing and your off and running.
