I've had my '65 FS running and driving now for about 2 weeks. I've got issues with firewall flex like others on FABO have written about, that I didn't pay much attention to until recently. My car has been converted to manual front discs using the Raybestos dual pot master with the 15/16" bore, and the clutch is a Borg and Beck type, and both require a significant amount of pedal effort. I get firewall flex so much that when I clutch or brake it will visually move the other pedal and you can see the master cylinder move. This is a big problem and is affecting the clutch operation and making the brakes feel like pressing on a spring. I clearly need to strengthen the firewall and trying to find the best way to add reinforcement. I know one approach is making a strut from the shock mount to one bolt on the master cylinder, but before I start fabbing something up, does anyone know of a vendor that makes that bracket, or can you share pictures of the bracket you made and works for the application?
