dodge71demon
I am working on a friends 69 swinger and he would like the front bench seat firmed up.What's the easiest and best way to get like new firmness to the seat bottom.The seat is out of the car now
Sometimes, if the springs are cutting into the foam, you can put a piece of carpet between the springs and foam. Try it first, and if it's better you'd want to glue the carpet in place. I've even used a some cardboard for the same trick on a saggy seat in one of my old beaters.
seat is out of the carI am working on a friends 69 swinger and he would like the front bench seat firmed up.What's the easiest and best way to get like new firmness to the seat bottom.The seat is out of the car now
Do you plan on removing the seat cover or are you just looking for a quick fix?
