First post: '63 Dart in the UK
ep16
New Member
West Sussex, UK
Hi all, this is my first post although I have been browsing around for a while. FABO seems to be a great little community.
I am looking at buying a '63 Dart over here in the UK. The car has already been imported and run around for a little while by the importer. Before I buy, I have a few questions to ask here and then I will start a proper build thread if it goes ahead.
A quick bit about the vehicle; it is a '63 that has already had a running gear swap from a '74 Duster including the 318 with stock two barrel, A833, 7 1/4 rear end, suspension and big pattern brakes (discs on the front) so should make a really good base for something very fun.
The plan will be to build up the 318 (or a second one at least) to get in the 350-400hp range @6k rpm at the flywheel as they are readily available over here and will be more fun on our roads in a light car with a 4 speed rather a 360 torque monster. This leads me on to my first question; will the stock 318 crank survive in this sort build or is it better to be safer rather than sorry and go forged?
The second question is; how interchangeable is the early suspension with the later stuff as I see most of the Hotchkis kits for example are listed as either '67 or '73 onwards? The importer says it has all the stuff mentioned above including the suspension off the Duster, just wondering if it is even possible to swap the early/late suspension? If not, what bits is it likely to have from the later car to achieve the above? Is it just spindles, rear end and the later brakes?
Thirdly, at what point is the 7 1/4 likely to let go? Some seem to think they are disaster waiting to happen behind even a stock 318... If anyone has an A body 8 3/4 they are wanting rid of, feel free to drop me a message as the chances of me finding one over here are pretty much nil!
I look forward to hearing peoples opinions and hopefully becoming a more active member assuming a deal can be struck.
Welcome! I'd say that a 7 1/4 would hold up fine with a 318 until you bump the HP to 350-400 and add a four speed. I'm sure they're not very common over there, so start looking now. Other rear ends can be made to work.
As far as the Hotchkiss stuff fitting an early A body, I'm sure someone else will chime in but I'll say probably not. Shocks might be the same, but sway bars are different for sure.
Cheers guys. It already has the 4 speed so it just needs the rear end and some handling before building the engine. Hoping to see it this weekend but it may be in a few weeks as I am away on holiday. Can anyone recommend suspension/handling supports for a '63? Probably going to go 2 " dropped spindles and an inch or so out of the rear as a starting point.
Thanks. I will keep the price close to my chest at the moment as I do not want to make all of you Americans cry! ...with laughter that is. Seriously, you would think I am mad! I am not saying that is not the case, but that is besides the point! Haha
The price of classic cars over here has just gone insane over the last 4 or 5 years. You will be hard pressed to find any road legal 60's, 70's or 80's American cars for less than what would be about $6k for you guys, no matter how questionable the the MOT inspection was!
