Dart Vadr
Thanks for taking a look at my post. I recently retired from the U.S. Military and I finally have the time and money to build my 1967 Dodge Dart GT (which has been in storage for the past 20 years) the way I want it. I've found a chassis/body shop that will media blast the car, replace any bad metal, install a chassis stiffening kit, mini-tub the rear, install an RMS Street-Lynx 4-link, and return the car to me in epoxy primer. I plan to run a Strange Dana 60 with 3.73 gears, 27" diameter 295/45-17 tires, and a Keisler 4-speed automatic with 3.06:1, 1.63:1, 1.0:1, and 0.70:1 gear ratio's (stall speed TBD will be matched to engine). Believe the curb weight of the car is roughly 3,300 pounds with me in it, but it may end up weighing slightly more or less after the body and engine have been modified.
This car is going to be a street car I doubt it will ever see any track time. Like everyone, I'd like the engine to make plenty of horsepower, but I'd really like to bias the engine toward generating a monster torque curve. I'd also like to be able to take it out on the highway and cruise at 2,200 to 2,300 RPM (70MPH with a 0.70:1 overdrive) for a few hours at a time without encountering major drivability issues. Lastly, one of my overarching design goals is that the car be as bulletproof as possible and that the car require minimal maintenance I like to wrench on cars as much as the next guy, but I'm getting older and I'd like to enjoy driving the car as much as possible.
On to the engine... I'd like to build a 408 CID stroker motor that can run on 93 octane pump gas at sea level. My proposed build sheet is as follows:
Block: Fully machined 360 (probably 0.030 over with pistons set at zero deck height and oiling system mods as necessary)
Crank: 4" stroke forged K1
Rods: K1 H-beam
Pistons: Mahle forged of 4032 aluminum with a 16cc inverted dome
Heads: Dr J's Airwolf 220 aluminum with 64cc chambers
Intake: Edelbrock Performer RPM Air Gap deep port matched
Cam: Lunati 20200713 Voodoo retrofit hydraulic roller cam (243/251 duration @ 0.050, 0.560/0.565 lift, 110 degree LSA)
Rockers: Competition Cams Pro Magnum shaft-mounted chromemoly rockers
Distributor gear: Crane 69970-1 Melonited (won't have to run a bronze distributor drive gear)
Timing Chain: Rollmaster timing chain
Timing chain Tensioner: Cloyes
Oil pan and pickup: Kevko
Oil pump: Standard volume Melling
Damper: Fluidampr
Water pump: Flowkooler
Fasteners: ARP studs everywhere
Gaskets: Cometic
Induction: FAST EZ-EFI 2.0
Exhaust: TTI 1 3/4 step headers
Ignition: MSD Digital 6AL ignition
I've calculated the static compression of this engine with .039 thick head gaskets at 10.42:1 and I've calculated the dynamic compression ratio at 8.54:1 with the above mentioned cam, so I think that it'll run on premium pump gas without issues. I've heard that pistons forged of 4032 aluminum can run tighter tolerances than those forged of 2618 aluminum, so I picked these pistons with the thought that they might offer slightly better durability in a long-term street engine. Also, I like the flow numbers of the Dr. J's heads and the price seems reasonable. Thoughts from the experts? About the cam, I was very impressed by the torque curve of the engine at the link below (the second dyno sheet). I've also heard good things about the Lunati Voodoo line and the duration specs seem to be somewhat tame for a stroker build. Again, thoughts? Lastly, I'd really like to run a 340 replacement block instead of a 360 block (remember, I want this thing to be bulletproof), but they seem to have lifter bar clearance issues with hydraulic roller cams. I understand that I'd have to make some changes if I went this direction. I'd appreciate any and all advice and constructive criticism that people are willing to throw my way. Thanks for your time!
http://www.forabodiesonly.com/mopar/showthread.php?t=263442
Rods: K1 H-beam
Damper: Fluidampr
Gaskets: Cometic
