So I'm putting together a 408 stroker and I went with the hydraulic roller cam from lunati. Now the pushrods from the flat tappet are too long, which I figured would be the case. Was wondering if I'm going to need custom pushrods are is there common premade pushrods for this switch over from stock flat tappet to hydraulic roller. I have stock rocker arm ratio and a 515/530 lift.
