360moparjunkie
What bolts can I successfully use for torque converter to flex plate? I have arp bolts in motor and flex plate to crank. I have b&m flex plate to hughes converter. Bolts needed are 7/16-20.
HP I'm guessing will be in neighborhood of 400+hp & maybe a click over 500 with a little juice. Gears are 456 spool w street slicks to be used. I'm concerned about strength.
Can I just use grade 8 bolts given my hp.
Have any of you used grade 8 bolts w similar setup successfully?
Thanks
Thanks
