pishta
I know I'm right....
level take a pretty good portion of the chain so determine your max lift with the leveler installed. I did this and ended up short on lift and I couldnt get it over the rad support. I ended up taking the pan off! But its pretty easy to do it with both mated, its just a long piece. I found it was easier to install with the motor mount brackets off. Lower into position and then install the mounts and brackets.
