Application
Pro Touring & Street / Track Vehicles
Requires
Housing with 3″ or 3 1/4″ O.D. tubes
Strange / Wilwood custom Pro Touring brake kit
Custom floater axles with crowned 24 spline outer ends
Simplifies Housing Construction
• Allows weld-ends to be directly aligned with carrier center-line
• Independent spindles available in 0.5°, 1.0°, 1.5° & 2.0° negative camber
• Individual toe plates in 0″, 1/16″, or 1/8″ per side (0, 1/8″, or 1/4″ total)
Versatility
• Easily alter configuration
• Change camber by replacing bolt-on spindles
• Alter toe by changing toe plates
Safety
• Vehicle weight and side loads are supported by the housing
• Axle shafts only requirement is to transfer torque
• Prevents the possibility of axle flange breakage
Performance
• Each hub is supported by two large tapered bearings
• Drastically increasing load capacity & wheel bearing life
• Solid spacer ensures proper bearing preload
• Eliminates excessive end play
• Prevents piston knock-back
• Pedal travel remains consistent during hard cornering
Includes
2″ O.D. Floater Spindles
• 4130 steel
• Provides rigid support for hubs & bearings
• Designed for 3″ or 3 1/4″ OD housing tubing
• 2.800″ OD tube end *
* Requires finish turning to suit axle tube ID
Steel Hubs
• Machined for 4 1/2″, 4 3/4″, & 5″ bolt circles
• Accepts Pro Touring 1/2″ or 5/8″ wheel studs
Equipped With 1/2″ Wheel Studs
• Upgrade available for 5/8″ studs
Steel Drive plates
• Designed for crowned 24 spline 300M axles
• Inner axle splines can be made to suit other differentials
Timken Tapered Bearings & Races
• Premium components from a trusted name
• Ensures proper fit & long bearing life
Solid Preload Spacer
• Prevents excessive preload
• Maintains consistency during hard cornering
Spindle Nut Wrench
• Properly mates to spindle nut
• Allows use of torque wrench
• Prevents spindle nut damage
ABS Option
Can be ordered to utilize 05-10 or 11-14 Mustang ABS systems
Option supplies custom reluctor rings & mounting parts
Please specify year of system
Options
5/8″ wheel studs –
OPRS13
Custom ABS rings –
OPAX10
Install spindles in housing –
H1130CSF
Axles – Sold as Each
20″ or less –
A5200M20
20 1/8″ to 24″ –
A5200M24
24 1/8″ to 28″ –
A5200M28
28 1/8″ to 32″ –
A5200M32
32 1/8″ to 36″ –
A5200M36
Brake Kits
All Kits Require Backing Plate Modification – See Instructions
11″ rotors & black calipers –
B2712WC *
12.19″ rotors & black calipers –
B2711WC
12.19″ rotors & red calipers –
B2711WCR
14″ rotors & black calipers –
B2714WC
14″ rotors & red calipers –
B2714WCR
* Provides clearance necessary for 15″ bead-lock wheels
This product is only available from an Authorized Strange Dealer or Factory Direct Call -
800-646-6718 or
Email Us
