66340SEDAN
FABO Member #3649
I am sure many here have a Fluidamper harmonic balancer but I thought I would point out some differences and some tips for an easy install for some thinking about this swap..... mainly the crank pulley cause the balancer is thicker than stock.
I have a 340 with a steel 1970 crank (internally balanced), when I built the engine I went with a cheap aftermarket harmonic balancer, probably China made but it worked great and came with weights you can bolt on for later 340 and 360's as well so i'll keep it for future use. I bought a used Fluidampr and finally got around to getting it ready to go on.
I am running the 70-up style stock pulleys, single groove lower one. The Fluidampr is thicker than stock, therefore, if you use the same lower pulley, it won't line up with the alternator. I went to a junkyard and found a single groove one on a 1969 Satellite with a 318, this is narrower than the 70-up ones and has a smaller diameter, so it will also act kinda like an "underdrive" pulley and maybe free up a little power...any SB 64-69 SB pulley should work for this. I did have to grind out the center hole a little to get it to fit over the lip on the Fluidampr, you will have to make one of the mounting bolt holes a little bigger too but fits nice and bolts on tight, when set on the balancer it lines up nice and should work great.
Here are some pictures :glasses7:
