forgot to put slide spring on kickdown at trans
gotdust57@yahoo
i forgot till it was over to put that little slide spring on kickdown at trans where the little nut and block is at where it pushes kick down back how much trouble am i in nut is tight and not moving? thanks
I would think it's there to keep your kickdown in the most forward position (I guess)...but I haven't seen a spring right at the trans before. You must have a different kind of setup. It's something new to me.
