RAYS 69 MOPAR
Well A 1964 a body 4 speed fit in a 69 abody
The speedo gear and cable is different, you can get one that will work, but you are severely limited as to the number of teeth you can find.
What about shifter position is it the same
shifter is in same place on A bodies. 64 and up.
What about the bell housing with the bell housing work
Yes unless you want to step up to the 10 inch clutch.
I'm sure a 10 inch clutch is a lot better right
