I'm sorry if this seems simple to a lot of you, it's just not to me. Maybe at some point down the road some other simpleton might stumble on to this and figure some this out himself without having to go through this process?
The good thing is that I think I may have found some new friends?
I do have some "High School car guys" left around here, one with a Grand National... but he pays too have a lot of the work for him. It gives him a good understanding but not really hands on.
I think I may have a guy coming here on Saturday. I won't have much (real) progress till then...
but... For those who care, (warning) I took two of the lifters apart. The plunger did not come out on it's own, as though the spring was stuck. I used the suction of my finger and pulled the plunger out. When I went to put the lifter back together suddenly I felt pressure from the spring to push it back in place again. Now I have spring tension that I didn't have before, but the oil is gone from the lifter as well.
So, I tried to pump the lifter with oil again, submersing the lifter with oil, and pumping up with a old push rod... The lifter now is not sucking in oil pressure at all, the feel is just the same pressure as the spring tension. I did read somewhere that I am suppose to use a syringe to fill the oil hole with oil, and then pump. Is that true? That might be the issue?
See this is why I thank you guys so much, because only you could have so much patience!
I called Lunati again, and ask what lifters they recommend. Ironically they suggest a different lifter then comes with the cam (of course). I looked on the Lunati's web site, and they don't even sell the lifters that come with the cam!
This is the lifter that they recommend: 71977
http://www.summitracing.com/parts/LUN-71977/
I am thinking, that I will get these... Just in case, and I know they are good.
Now these are my lifters that I did take apart... (and thanks as always!)
(oh, I have the plunger backwards... That's not how it came out... :toothy3
