fishy68
Tyr Fryr's Inc.
As the title says I have a freshly rebuilt 489 case 8-3/4 3rd member with OEM 3:23 gears and a sure grip for sale.
Has all new Timken bearings, new seal and a solid pinion spacer. Small 7260 (std. A-body size) yoke. I completely disassembled it, had the case hot tanked, disassembled the cone type sure grip and inspected and found to be in absolutely excellent condition (.080"+ clearance before the cones bottom out) so I just polished it all up and reassembled it, I pressed on all new Timken bearings, polished the ring and pinion and assembled it using a solid pinion spacer and setting the pinion preload and backlash. Set gear pattern and painted the housing cast coat grey. I also used Loctite on all the bolts and torqued them to factory specs so nothing will come loose on you. I attached several pics I took during the rebuilding process.
I'm located in central IL about half way between St. Louis Mo and Springfield IL 3 miles off of I-55. I prefer local pickup and can meet you within 100 miles if you can help me a little with the fuel cost.
At the present time I have nothing to ship this in so if it doesn't sell local within a few days I'll build a small crate for it.
$550 obo plus shipping
PM if interested
PM if interested
