I have a 67 Dart GT and I upgraded the front drum brakes with upper control arms and disk brakes from a 75 Dart Sport. My wheels stick out a little more
now than before which I knew about. When I go to get a wheel alignment - should they use the same numbers for caster/camber/tow as my original 67
had, or the numbers for a 75? I just called Midas and whoever I talked with
said it would cost more($125) because they have to do more adjustments
than normal. (don't know how you could adjust caster or camber on the 67
without one affecting the other but what do I know??) Now I think I'll just
take it to the place I bought the front tires from - I'm "assuming" I can use
the original alignment specs. Anyone know what the correct numbers should be?
