Then I await your geometric analysis breaking down exactly how much a 1° change in camber changes the overall ride height for an A-body.
I'm talking about camber on a static alignment here. A 1° swing with factory UCA's, even with offset bushings, is pretty significant.
You know, there are some really great tricks for getting by without turn plates. Just marking the floor with the angles you need is pretty simple.
But that being said, you can buy a set of turn plates for $170. Yes, they're nothing special and they won't hold up if you're running an alignment shop. But if you're going to do your own alignments they will simplify your life, and they'll probably last just fine for the number of alignments you're gonna do. These here and a set of short ramps (so you're not jacking the car, upsetting the ride height, and lowering it onto the plates) and you're in business.
https://www.amazon.com/8MILELAKE-Truck-Front-Wheel-Alignment/dp/B07JP91QWH/?tag=fabo03-20
You can find used turn plates online too, although the good ones weigh a ton so shipping can be a major problem.
