Hello folks,
Even though I lurk around the forums often enough, I rarely post on here. However, I need some help so perhaps you folks can help me....
The car in question is a 69 Plymouth with a 73' k member. When I bought the car, it came complete with new bushings for the front end. All parts were addressed short of the pitman arm and idler arm bushings. I will be replacing those with moog pieces, hopefully they do the trick. My question is, is there a certain sequence necessary to torque down the bushings? For instance, should i do the sway bar first? Or the lca's? Or the strut rod ends? I'm just a bit lost as to whether there is a method or if it even matters at all. Thanks in advance for any information.
Marvin
Marvin
