Front end shakes
I for the life of me cannot figure out why my cars starts shaking around 60 70 mph. I replaced everything in suspension but shocks so I figured rims because I had new tires last year. Replaced them still shakes. Any idea what I am missing
Front end alignment??? Wheel bearings OK & correct load?? Check to insure all wheel tire combos run true (vertical) and concentric (horizontal). If so, check balance.
Had it aligned last year and again this year after I upgraded suspension again. Going to take tires in weds for rebalance
See if you can find a shop that does Road Force Balancing. I had same issue and it's unbelievable how much some of these tires and rims (new or not) can be out of round. The road force allows the tech to get the tire and rim as true as possible by rotating the tire on the rim and simulating the force of the car on the road. If solved 90% of the issues I had.
How about the dreaded 'cowl shake' ? Had a convert once..all new front end,bushings,shocks,tires,balanced..still there. Added frame connectors..gone.40+year old unibodies.
