BigBlockMopar
BigBlockMember
IMO, learning how to fab your own headers and buy a Borgeson P/S box is way cheaper than what I'm all seeing here.
Had already figured that as I mentioned many times already.You're gonna have to alter the rack as well or find a shorter one.
Like I said earlier, it has been done successfully before. As for welding it, of course I would have a pro do it as I have zero TIG experience. As for why I believe Gerst and Denny wouldn't even consider the Crown Vic cradle is the fact there is no way to make it a bolt in deal without some pretty significant alterations to the A-body chassis. I mean, seriously, how many of you would cut their A-bodys frame and inner fenders along with welding in the necessary reinforcements?There's a reason no one has put a Crown Vic front end in an A-body. Yes, the swap has been around for awhile with hot rods and trucks. Typically, those applications all leave the Crown Vic suspension cradle intact. The reason for that is the crown vic cradle is aluminum. Cast aluminum. Sectioning and narrowing it is not something that the home welder should take on. Yes, it can be done, there are places that repair cast aluminum rims and motorcycle frames. But it's not an "enthusiast" level project. You should enlist an expert welder for that. As someone that has successfully TIG welded cast aluminum before, I wouldn't want to make that particular modification because of the loads involved. Obviously there's a first time for everything, but the Crown Vic suspension cradle swap has been around for a pretty long time. Long enough that guys like Denny and Gerst would have definitely had that option available to them. It wouldn't be a bad business model to take Crown Vic cradles, modify them, and sell them for use on Mopars. It would be a pretty simple gig once you had the jig set up and a welder that wanted to do it. And yet, multiple different company's have instead chosen to completely fabricate their own suspension.
Track width would be narrowed down to match the stock A-body spec. That's 1.9" per side (3.8" total). While it would have less roll stability than a stock width CF suspension, can you say it would be less than the Mopar suspension it would be replacing? Stiffer springs shouldn't be a problem. I think the stock springs would at least get it in the ball park considering they're meant for a 4000+ lb CV and not a 3000-3500 lb A-body.Narrowing the track width will effect how the suspension handles. By narrowing the track you're decreasing the suspensions roll stability, you'll get more weight transfer during cornering. That will require stiffer springs and larger roll bars than a standard set up. The geometry remains pretty much intact, but it won't handle exactly the same as an unmodified set up.
I'm not seeing how the load changes that much from horizontal to vertical. With the same spring rates (torsion vs coil), and the same fulcrum point, and plane of motion, the front end should see the same loads as long as the coil spring is not being directly supported by the inner fender itself. The CV suspension loads everything right on the frame rail and not the inner fenders. I really would like to see some actual mathematical calculations that show there is a difference. Regardless, I was already planning to stiffen the entire chassis no matter what suspension I run so I guess it's a moot point.And again, you're adding a crossmember that loads all of the suspension forces into the chassis vertically, just like the coilover conversions currently out there. The Mopar unibody chassis was not intended to be loaded that way, it carries all of its suspension loads horizontally in the K frame and torsion bar crossmember. There's very little vertical stiffness in the front end, even cars with the stock torsion bar set up have a ton of flex in the front. You would still need to significantly stiffen the front end of the car to run the Crown Vic suspension. And, how much better are the suspension numbers for the Crown Vic? Does it have better camber gain or less bump steer than a properly set up torsion bar system? Or is it just another way to convert to a rack and coilovers? Stock Crown Vic brakes are only 12", you can bolt on a set of 11.75" rotors using 73+ A or FMJ spindles and a set of the larger caliper brackets, which Dr. Diff sells for $90. If you go bigger, then you're buying an aftermarket brake kit anyway. Yeah maybe the Crown Vic aftermarket kits are a little cheaper, but you have to completely change over the suspension with significant custom modifications to even make it possible.
Already have a properly setup torsion bar suspension with heavier bars, rebuilt front end, Addco 1-1/8" sway bar, and SSBC disc conversion. It could be better but it is decent.By the time you buy the crown vic suspension, modify the cradle, modify the A-body chassis to accept the crown vic cradle, re-work the steering column, sort out what to do for a steering rack, fabricate new engine mounts, figure out what fits for headers and oil pans (or if you'll have to go custom), and get the thing generally sorted you'll have at least as much money into it as properly setting up a torsion bar system, or buying an HDK or GST set up. Not to mention the time it will take to do all of that. Even if you did all the work yourself and came upon the Crown Vic suspension for super cheap I don't think you'd end up money ahead.
Eh, just would like things to be better. That's all. What's wrong with that? If the stock suspension was so great people like Denny, Gerst, etc. wouldn't be in business selling complete upgrades for it now would they? Lastly, I just like to think outside the box and of other possibilities. There is no harm in that!I like the tubular k-members a lot, and will probably go that route one day. But I don't see any reason to completely convert the front end. I have Dougs headers that took a little massaging to give me more clearance, am running a mini starter, shorty oil filter, and ujoint steering coupler, and feel fine with everything. Eventually I will go the tubular aarm route, but am not sure why you feel the need to do so much for such small issues.
More power too you, but reinventing the wheel is rarely pragmatic.
The big advantage to the CV brakes (and the rest of the front end) is that I can literally go to any auto parts store and find replacement parts in stock locally. In addition, there are quite a few more rotor and pad options available for it over anything Mopar. BTW, I already have SSBC disc conversion for it but the replacement parts for it cannot be sourced locally at all. Remember, this would be a daily driver so parts availability is a concern.
Now, for the cost side, there is no way it would cost anywhere near $3000 or more. That's just ridiculous to even think it would be near the cost of a HDK or Gerst setup. I can see that you're doing your best to discourage me from this path. That's cool. Never said I was going this way. It was just something I was spitballing and is purely academic at this point. While I do think the CV suspension does fit the bill in some respects, a lot more research in to it would be necessary before I would actually move forward with it. I was really hoping this thread would enlighten me to some other possibilities. I guess there really isn't any unless I come up with something on my own.
No, have never even thought about whether the CV suspension is better or worse. Like I said, just throwing it out there, thinking out loud so to speak!Here's the thing......is a crown vic front suspension truly a better handling suspension or are you just guessing?
Do you know how much a welder is going to charge you to TIG weld that up? I was quoted over a grand to have my 4 link welded in professionally by 4 different shops here in town. Aluminum would cost even more I'm sure.
Nothing wrong with thinking outside of the box. Nobody is saying that. But sometimes outside the box isn't better. And sometimes it's even worse.
Here's a few questions I haven't seen an answer too. What shocks are you running, what tires, and lastly, what's your rear suspension set up?
I'd ditch those shocks and get you some that are dual adjustable or go Bilsteins. Also, tire compound matters a TON. Before you go butchering a car, try different tiresNo, have never even thought about whether the CV suspension is better or worse. Like I said, just throwing it out there, thinking out loud so to speak!
I guess it probably helps that I know a few professional TIG guys!
Shocks currently are Edelbrock IAS front and rear. Tires are crappy BFG's on 15" steel rims. Plan on moving up to 17" or 18" with better quality rubber. Rear has Mopar XHD leaf springs, Strange Engineering S60 Dana w/3.73 Trac Loc, and Addco 7/8" sway bar.
Oh, I know they aren't the best shocks but they're ok for a daily driver. Will definitely upgrade them when they are ready for replacement. Remember, I'm not out to build a full drag or auto x car. Just a really nice driver. I'm sure probably just going to some 18's and some Nitto 555's would totally change things.I'd ditch those shocks and get you some that are dual adjustable or go Bilsteins. Also, tire compound matters a TON. Before you go butchering a car, try different tires
The only thing I really don't like on the Mopar front end is the steering gear. IMO, standard or quick ratio, power or manual, they suck, period. Eh, guess I'll just live with it. However, thanks for the awesome feedback and discussion!
I thought the aftermarket Mustang II suspensions weren't that good on a daily driver? I've been out of car scene for quite a few years so maybe things have changed?Put a cheap Mustang II front clip in it if you want something different, you can get them for $1500 from places like Fab Quest and you could sell the stock front clip and get some money back....I would do that before the CV front.
Depends on who's kit you're talking boutI thought the aftermarket Mustang II suspensions weren't that good on a daily driver? I've been out of car scene for quite a few years so maybe things have changed?
In this case, if that's all you're after, it'd be a complete waste to try the cv set up.Oh, I know they aren't the best shocks but they're ok for a daily driver. Will definitely upgrade them when they are ready for replacement. Remember, I'm not out to build a full drag or auto x car. Just a really nice driver. I'm sure probably just going to some 18's and some Nitto 555's would totally change things.
Haven't tried a fast ratio P/S box. Not familiar with the Borgeson unit. I've tried the manual fast ratio and that sucked in city driving.In this case, if that's all you're after, it'd be a complete waste to try the cv set up.
Have you actually tried one of the fast ratio boxes or the Borgeson unit?
Well I'd try the Borgeson unit before doing anything else. I've yet to hear anyone not like it.Haven't tried a fast ratio P/S box. Not familiar with the Borgeson unit. I've tried the manual fast ratio and that sucked in city driving.
Being that A bodies are unibodies adapting another
cars chassis is much more difficult than overcoming
the header clearance or cost of the available kits for most builders.
Then there is the bucks down hands on type guys that prove everybody wrong.
If I was to have a go at sidestepping the cost and
header space issues normally accociated with an early A I would be looking for a low cost donor A100 straight axle leaf setup. Guys have done it this way
since the early 60s. Problem solved. Information is
out there if you dig a bit.
Exactly! See, it's not $1000 to get it welded up.About the narrowed Crown Vic. Saw this link not to long ago:
Products | RITCHEY CLASSIC TRUCK SUSPENSION
Yes, the one they offer is too narrow.Yeah.... but.... I believe the stock CV IFS cradle is 35 3/4" between the shock towers. If 4 3/4" is cut from the center (from the website), that makes it around 31" between the towers. isn't that TOO narrow to fit the A body without surgery on the front frame rails?
I see you live in Tuscon. How about contacting El Polako up in Phoenix:
Product Tags Crossmember
They do Dodge Dakota cross members for various applications. Very close to an A body. VERY close.
Greg
