prodart340
well the latest project I have under works is replacing the power steering in my '74 swinger with the manual box,column,pitman arm,drag link,and center link from a '69 swinger. When I change this out I will also be using the"c" body tie rod ends and aluminum adjusting sleeves which leads to my question, will I have to ream either the center link and/or the spindles to get this all to fit or will it be a direct bolt in? thanks in advance, mike
