Enjoying it again
Need some help please. Have a frozen/seized lower left alternator bolt on a 318. This bolt hold the two metal brackets for the alternator and passes through the water pump and timing chain cover into the block just above the fuel pump opening. This bolt is seized. Any suggestions on what to do so as not to snap this bolt in two? Thank you in advance.
