Before you get into this, check out lyngsat.com for available ku band birds and programming, make sure you are looking at unencrypted ku band. 99% of the fta channels stream now and links are on this site although they look streamed, ie. Low frame rate and low def. You can pick up a Roku streaming device for you tv off your 3Mb /sec or better internet connectionfor $50
Ok, Here is my story in a nutshell, bought a fta receiver at goodwill, 13 bucks. Buy a lensatic compass! I didnt have one and relied on satfinder.com for visual line of site, close but no cigar. Spent another 9 on its remote, and another 6 on a sat finder. Then bought a 6 buck LNB as i was convinced mine was shot. Then another 30 on a bigger 70 cm offset dish. Couldnt aim the dish so the Q was more than 0 although the signal was 99 (?) So i borrowed a buddies birdog sat finder. It tells you what sat you find by name unlike the geiger counter meter. So i identify 1 (91w G17 i believe) and determine which headings are listed and calibrate my headings and elevation on the mount. I reprogram the birdog to find G19 ( the big gun of FTA @ 97w) and align it. still no Q until i force a blind scan on it, then it lit up with 178 channels! Id say 30 are english speaking, 80 are islamic, and the rest are just foreign. And all of 2 are worth watching! Unless you are a Jesus freak ( nothin wrong with that) you will be disappointed in G19. If you can get a motorized mount, then you open yourself to about 40 other satellites and 1000 more channels but the old saying is "if the station is good enough, it wont be free (to air)" still kinda fun to dabble in your own sat downlink.
And you do need a FTA receiver to IKS, as well as a circular polorized LNB (generic triple LNB dish pro 500 is good one) and an internet connection as well as a wizhub (serial to ethernet adapter) or an ethernet capable receiver. You cant hack a commercial DBS receiver anymore. My Sonicview premier was ordered destroyed (existing inventory) by a court order! Seems it had bits of proprietary Dishnet code embedded in its firmware designed to circumnavigate the Dishnet encryption. Oops! If you can find ION free to air on ku band, then you can watch He-Man re-runs on its Qubo channel! By the power of greyskull!
