I reinstalled the wiring in my 74 Duster, and I just realized that I don't currently have a wire going between the fuel sending unit and the fuel gauge. I remember from taking it apart that the wire enters the cab through a hole in the floor pan above the sending unit, however I don't remember if that wire connects to the rear wiring harness or how it gets back to the dash. I tagged the connectors on my rear harness and I didn't have any extra connectors or wires there.
Even when I went through the dash wiring harness checking for issues, I don't remember seeing a connection point fore the fuel gauge wire. Does anyone know if this wire goes back all by itself to the gauge cluster or what? I started to look in the FSM but haven't found anything yet.
Also, I intend to use braided line for a fuel line from front to back, so will I be OK to replace the ground strap that bridged the rubber hose section to the original steel line with a ground jumper to the chassis?
Cley
Cley
