[WANTED] fuel line from pump to 2 brl.
RedFish
73 model 318. I want to replace the 2 pieces of steel fuel line from mechanical pump to 2 brl. carb. This setup positions the fuel filter vertically by the water pump.
I've had R.A. for 35 years so I feel you . But a few friends and a $10.00 tube bender goes a long way . I had a 2bbl fuel line in my stash but I think I tossed it . Let me check .
I tried that part number, no results
Click on CATALOGS in the header.
Scroll down, click on Mopar Catalog.
Click on Brake & Fuel Line Plymouth (Dodge) A-Body.
Click Next Page.
Zoom in
67-76 A-body Engine Lines
Easier yet, call
Alan
OK, found new, listed for 73 and 74 models.
I'll wait a bit to see if good used shows up here.
I have these
I have the original ones that should work. It's off my poly 318, 2bbl BBD, front fuel inlet. Drops down behind the alt bracket. Let me dig it out and I'll post pictures. Still in nice shape.
OK guys, the later "unleaded fuel only" models had a thicker base gasket under the carb and the fuel filter was moved to vertical and down beside the water pump or between alternator and water pump ( reduces fuel percolation ). I have the fuel line with horizontal filter above intake. That's not what I want. Thanks though.
