rmchrgr
Skate And Destroy
AAARRRGGHHH! Frustration!
Soooo - I put a new tank-to-pump fuel line in my Duster. It's aluminum using AN type fittings. Got it all bent up and connected. Now there is NO FUEL to the carb. Not sure how this happened but there is no fuel even getting to the pump.
Here's the sequence of events that led up to this point; removed old aluminum fuel line with rubber hose connections including metal canister fuel filter by the right rear wheel. Install new aluminum fuel line with AN fittings and Russell Pro Classic braided line from hard line to pump in engine bay. Install new XRP in line fuel filter with -6 connection to hard line and regular flare to -6 adapter where the old filter was. Go to start car, no fuel in carb bowl, no fuel to pump. Swapped fuel pump with the old one, no change.
When I first did the fuel filter, I used a compression fitting because it was really difficult to flare the end of the line from the tank. I installed it and it leaked right away. I ended up leaving it overnight because it was late. It leaked continuously, enough where there was large puddle underneath the connection the next day. I disconnected it to see what was happening and ALL the fuel drained from the tank, like almost 10 gallons. I didn't expect that to happen, what a mess. Got that under control and managed to reconnect everything. Eventually, I was able to flare the line and put a fitting on there but it's loose. Clearly I will have to remedy this with a better fitting.
I'm pretty sure this is my problem right here but it does not add up. Even if the fittings were loose or connected poorly, fuel should still be suctioned from the tank through the line. Again, no fuel anywhere.
After the fuel drained, I put 5 gallons back in. Was thinking there might not be enough fuel to suction but 5 gallons should be plenty. There is no sump in the tank, just a stock one. The line from the tank runs from the sender to the right side frame kick up, down under the wheel well and to the passenger side frame rail.
Gas is Cam 2 GT 100 octane unleaded.
Thanks for any input, need to get this resolved!
