Cope
Fusing with fire
Just got the dart running and went out for a drive. My fuel pressure is way to low, like 2.5 Lbs. Not sure if my regulator is bad or if I have it plumbed wrong?
I have the regulator adjusted all the way up. (Screw turned all the way in per instructions.) And it's still not over 3 psi?
Pump is summit eletric and new.
Bottom -8 line is fuel in.
Left side -6 is fuel to the Y block.
Right side -6 is return line.
I thought both sides labeled our
would be regulated but it seems like it's just pumping right back into the tank?
The regulator is a cheep Holley one.
Did I screw up the plumbing or should I get another regulator?
Thanks.
Thanks.
