mopardude318
I'm installing my 408 stroker into my 68 barracuda. I have to use an electric fuel pump, as I don't have a mechanical fuel pump eccentric because of the Milodon gear drive. LOL
So I will be using a Walbro GSL 392 pump, with the Aeromotive Pn:13204 carbureted bypass regulator.
I previously installed a new fuel tank, 3/8 sending unit, along with new replacement 3/8 fuel lines. I know I need to plumb a return, so I will also use 3/8 aluminum line and run along the factory fuel line. The sending unit has a 1/4 provision built into it. I was thinking of using that for the return into the tank, but possibly is too small?
I plan to mount the pump is this area somewhere, along with a 100 micron pre-pump filter.
What are your thoughts?
This is the 1/4" provision I mentioned earlier.
