Fuel pump pushrod length
mad accountant
Plymouth, MN
Anyone know what the correct length for a fuel pump pushrod in a 383, and what the wear limit is/may be? Having a fuel delivery problem and I've exhausted just about everything else.
I don;t actually know the spec. I always just replace them. If you can see waer on the tip that's on the cam - just replace it. Normally if it's gone to where it would cause a problem - you'll be able to see it.
