Can someone explain the fuel sender circuit??? I know it acts on resistance does that mean the voltage from the gauge varies????? replaced a fuel cell and gauge does not work ,I know the mopar gauges are 10 to 70 ohm's but don't understand the voltage at my main post on the sender is only 4.5 volts?? should that be 12 volts or does that vary on how full the tank is??
also is the 10 ohm's empty or full?????
