synchro66
I have just installed a new sender unit into my Valiant Charger build here in Australia. There are two tabs on the unit and Im not sure which is power and which is earth, as per pic. any ideas?
Doesn't look like any a body sender I have seen..I wish we had seen if this sender is exact reproduction of OEM before it was installed
You need to turn the lock ring a little more. It isn't in the locked position.I have just installed a new sender unit into my Valiant Charger build here in Australia. There are two tabs on the unit and Im not sure which is power and which is earth, as per pic. any ideas?View attachment 1715660241
