Drache
1971 Dodge Dart Swinger
Is there a formula for knowing how much to gap sparkplugs?
I have a 318 in my car but it's not exactly stock anymore.
What kind of ignition system are you running?
Do you mean the distributor? Im currently on the original mechnical type but my mechanic will be switching my over to a HEI type first thing tomorrow morning.
You'll need to experiment, but let's talk about you choice of ignition, HEI? Really? Did your Chevy mechanic talk you into this?
No actually my cousin owns the shop. My original distributor was really worn. He happened to have one of these in his lunch room:
http://www.topstreetperformance.com...ibutors/ready-to-run-chrysler-318-sb-red.html
He gave it to me for free, I just had to pay for the install.
Yes it's far from the best but I also am on a strict budget right now due to work.
man that looks like it will be a tight fit on an abody.
OK, I understand that very well. Good luck.
I seriously think it won't fit :sad7:
Good luck?
Should I have wished you bad luck? lol
I've never gone past .045. I don't fuss a lot with plugs. So factory type ignitions get .035. NO2, gets .035. MSD, or an upgraded ignition/coil package gets .045.
Some of the old GM products from the late 70s and early 80s ran as much as .080" plug gap.
Err-ruh you sure about that? Biggest gap spec I ever saw was 0.060", which is pretty enormous. Have never sen a spec anywhere near 0.080".
Factory specs go as large as .080 on GMs and .060 on Mopars. That was for emissions in the 80s and early 90s
I always figured it's more energy in a smaller area (meaning hotter spark) when the energy is sent over a smaller gap.
