AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 24,952
- Reaction score
- 12,303
I think 62cc is gonna be too small.Way too small
Here is the math; (4.07bore/2) x 3.1416pi x 3.31stroke x 16.387conversion =705.68cc swept
and 705.68/(11.2maximum Scr - 1) =69cc minimum total chamber volume.
now the minimum chamber volume includes the head,the deck,the gasket,eyebrows,etc.
so if the 340 has pop-up pistons, say .045, that is a deck height of -9.6cc;plus gasket of 8.9cc, plus eyebrows of say 5cc, that already totals 4.3cc. So 69 less 4.3 = 64.7 the minimum head cc to achieve 11.2 Scr. And to suck 11.2Scr down to 8.5/9.0 Dcr is gonna take a bigger cam than what you currently have in there.So really, 62cc is waaaay too small. But back up the bus aminute. I have assumed a deck-height of .045pop-up, which is the 340 blueprint spec.. You may have less. In fact, you could have anything in there,including in-the-hole pistons. And they may not have eyebrows.And the no eyebrows is incredibly important at this time. And the gasket could be half as thick. Or twice as thick. What I am saying is do not make a move until at least one head is off, and all the pertinent measurements have been made, and the final camshaft has been chosen.
If you like where the current cam is putting the power in the rpm band, you may wish to keep it. And if that is so, it behooves you to determine the ICA (intake closing angle). From the measurements you get and the ICA, you can back calculate the exact head volume to achieve run-ability on your 98 octane gas. It may not even be possible to hit all the targets (The targets being; Scr,Dcr, and 98gas.) with what you currently have, or propose.There is a strong possibility that the pistons will have to be changed or machined. So,
Off with a head! lol
