MidnightBlueSwinger
Member
I'm gonna try this next fill up.I go low tech.
I insert the fill nozzle, but leave it out an inch. I then take a couple paper towels and turn them into a big long fatty (420 man) then wrap it around the filler nozzle. Then push the nozzle the rest of the way in.
I also glow slower than the max and do not top it off
I tried the ¾" valve cover grommet, didnt work as i hoped.Couldn't one just get a large grommet and put it into the fill hole?
Kinda like a rubber sock you don't have to carry around and remove and toss.
Still doesn't solve the issue though.
I have a TanksInc tank, it has a separate vent nipple. It's connected to the factory fill tube vent, hard line up and around in the trunk, then soft line down and out into the frame, iirc.
Even if I fill it extremely slow it shoots out in the end, sometimes getting a full tank, sometimes not.
TanksInc tank came with a aluminum breather valve, but it needs to be mounted high, which would be in the trunk, no thank you, and I misplaced it.
My other thought, fill tube in my 62 Valiant is horizontal for a mile before it goes south.
Filling from a gas can one day, I stuck a hose on it to avoid wearing gas.
Maybe carry a hose that just reaches the full tank mark and stick it on the pump nozzle?
Would you stuff a ¾"id x 2 ft fuel hose down the filler tube, then attach the hose to the pump nozzle? When I bought my 64 Falcon the PO said to attach a ¾" hose to avoid spills, I'm thinking thats what he meant. Does this sound right?
