Gas Tank Filler Relocation Question
Fuel and Air Systems
  1. crashcaptn
    crashcaptn 1965 Dodge Dart GT
    579
    25
    Jan 15, 2007
    San Diego, CA
    Local Time:
    1:26 PM
    Has anyone relocated their filler location to the inside of the trunk for modern gas pumps in the early A's? I'm curious if there's products to complete this idea or how others have done so.
  2. Alaskan_TA
    Alaskan_TA Well-Known Member
    4,559
    2405
    Nov 12, 2004
    PA
    Local Time:
    2:26 PM
    Inside the trunk is a bad idea. Any vapors could get into the passenger area.
    Best to let the vapors vent outside the car.
    • Agree Agree x 2
    • Alaskan_TA
      4,559
      2405
      Nov 12, 2004
      PA
      Local Time:
      2:26 PM
      Also......
      If you are having trouble fueling with modern pumps, try holding the gas nozzle upside down next time. (hose pointing up)
      It works for me.
      • Thanks! Thanks! x 1
      • crashcaptn
        579
        25
        Jan 15, 2007
        San Diego, CA
        Local Time:
        1:26 PM
        I'll give it a shot! I usually just kneel down and press in and hold for like, 12 gallons.. i saw a ford falcon where some guy relocated the neck into the trunk and put a modern cap on. was wondering if that would be a way to go
      • mycuda
        mycuda FABO Gold Member FABO Gold Member
        5,074
        2388
        Feb 15, 2011
        Chicago/ Metro
        Local Time:
        1:26 PM
        Im putting flip top gas cap from 67 up on my 65 Dart project for this reason. I was able to use a portion of 67-69 cuda sheet metal and weld 6" higher to make more usable than stock.
        You could still get an adaptor for flip top if interested in original location to eliminate stock situation.
        Dave
      • Cuda Al
        Cuda Al Well-Known Member
        797
        785
        Oct 21, 2007
        Lompoc, CA
        Local Time:
        11:26 AM
        I think this is uniquely a California problem as we have small nozzles and the vapor boot. I just shove it in as hard as I can and hold it, I do not depend on it hanging there on its own.
        Alan
      • RogerRamRod
        RogerRamRod The Older I Get, The Faster I Was
        836
        439
        Jul 5, 2011
        Chesapeake VA
        Local Time:
        1:26 PM
        “just shove it in as hard as I can and hold it,”
        Sounds like how you play Rodeo.
      • mycuda
        5,074
        2388
        Feb 15, 2011
        Chicago/ Metro
        Local Time:
        1:26 PM
        sounds like my first girlfriend
      • boydsteve
        boydsteve New Member
        2
        0
        Aug 28, 2018
        Lakewood, CA
        Local Time:
        11:26 AM
        New guy here, 63 Valiant Convertible. I have the CA pumps but I can get gas to pump with it upside down but it only takes a little fuel and then dumps out all over the place. today i ran out of gas with my experienced mechanic with me in the car and then went to the station and it took 4 gallons before dumping out. I let it sit and then tried again with the same result. Any thoughts? Could a vent line be plugged or something preventing more gas from going in?
      • Alaskan_TA
        4,559
        2405
        Nov 12, 2004
        PA
        Local Time:
        2:26 PM
        If you were holding it at 'full trigger', try half trigger.
        The fuel neck opening around the fuel nozzle should allow air to pass easily, so it should not be a venting issue.
        Modern pump flow on full trigger can be too fast for older filler necks though.
      • Sc2ner
        Sc2ner Well-Known Member
        64
        32
        Mar 21, 2013
        Farmington, MO
        Local Time:
        1:26 PM
        I moved mine to the top. It is still uses part of the factory neck where it mounts to the quarter, for now. I will be changing to a flapper/vented inlet. Before installing the new tank, a vent was welded in. It will have a line added to the inlet vent tube.
        So the fuel spillage shouldn't happen. I do fill at half speed. If i filll fast the escaping will burp fuel out.
        Find a vented/flappered filler neck and mount it to the stock location. I have one off an S10, but i have seen universal necks for sale.
        • Like Like x 1
        • boydsteve
          2
          0
          Aug 28, 2018
          Lakewood, CA
          Local Time:
          11:26 AM
          thanks, it definitely wasn't a flow issue, I was going slow and the tank was full (at least the neck was full). any thoughts on checking for proper venting? Spec seems to indicate a non-vented cap and the tank I look for sale for this era say 'no vent tubes', could all that be part of it? i was thinking of 'filling' it up, then siphoning it out to see what I get and going from there. any other suggestions? My gauge doesn't work so I might have to pull the tank anyway.
