Gen III 5.7 mounts vs LA Series mounts
msmrinc
Active Member
Madisonville, TN
Are the Mopar Gen III 5.7 Hemi k-member mounts the same as the LA series (273, 318, 340, 360) mounts? I've got a 67 Barracuda with an after market K assembly with a 5.7 installed, going a different direction (putting a 273 back in her), are the mounts in the same location?
Most of the time the K frame itself isn't changed. An adapter mounting bracket is used in between the K frame and the motor for the hemi swap. It is a bolt in deal. If you have engine mount brackets for your 273 on hand you are likely good to go.
