GilValiant65
Member
Hello, I am glad to be a member. I think I will need help from the start, I have been doing cleaning and more cleaning but I would like to get some action on the engine compartment. I replace the old coil due to a no spark situation, cleaned all contacts and no luck or no spark. I replaced the ballast and no spark either. I did not replace the condenser since it controls the spikes but should not affect having a spark.
I am getting about 11 volts at the positive of the coil and at the end of the coil cable to the distributor when the ignition key is on the on position. I installed the new coil the same way the old was, the negative goes back to the distributor. The condenser and the green wire goes to the positive.
Any recommendations? Thanks A Gil
