AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 26,618
- Reaction score
- 13,855
You can't go wrong with MRL
Is there anything that I need to be concerned with swapping the 340 for the 360 that will not be compatible?
Good deal on the 360 damper. And no problemo... we all started in this world knowing exactly zero!
Find out if:
1. The flexplate being provided is balanced and is to be used with a 360 TC, in that case, you need to get a imbalanced TC for a 360.
or
2. The flexplate being provided is imbalanced and intended to be used with a neutral balanced TC, in which case you get a neutral balanced TC or knock the weight off of your 340 TC.
You do know that the MRL 360 Classic Cruiser is going to totally spoil you right? Just PM ME when you are ready to dump the 340....I could use another one LOL
I think your choice was the best way to go, getting a 'brand' new engine from a highly trusted "local" engine builder might be costing you but it will be a "once and done" deal where once that fresh 360 is in there you will never have to worry about it again.
Another point, when I got my 360 balanced at the machine shop I gave them a weighted B&M flex plate I got with a bunch of other parts; I got a call one day saying the balance on the flex plate was way off and wouldn't work with my 360, and later the machinist told me he figured out it was a plate for a 1973 cast-crank 340. Apparently the 1973 340 are balanced differently than 360s, at least according to my experience?
That is correct.@MRL Performance if you're around maybe you can shed some light? Basically what my machinist figured out was the amount of offset-balancing between the two engines is actually different (1973 340 vs. 360)...
