BARRACUDA340S
Well I had it pretty much ready to go in by the time my buddy came over to help. I made my own brake lines and had it painted etc. It pretty much just slid right in! It took maybe an hour from start to setting the car back on the wheel's. I need to put in the prop valve tonight and bleed the brakes. If any of you are considering doing this go with moser. Everything fit perfect and the axle measured out perfect so the tires are right where they are supposed to be. My drive shaft even fit. I couldn't be happier
