Got the K-Frame Blues
draginmopars
Shady Hills, Florida
Was carefully trying to remove the spool mounts from the K-frame
to use it as a big block k-frame
something wasn't setting right after I got the driver's side mount off..
Hummm, let's set it onto the frame rails
YEP, dang thing is twisted, one corner is 1" away from the frame rail
then tested 2 other k-frames, (don't want to cut them up> small block/spool and a 340 k-frame ), they set flat, so, it's not the frame rails
So, the lesson today is check the fitment BEFORE modding the k-frame
Lucky, I have another slant k-frame , but, it's still in a parts car, with eng/trans
(read>>> MORE Work)
Of course, the extra k-frame i had..
Gave it away last year, to a member that needed it more than I did at the time.:D
So, if anyone needs a steering box mount or idler arm bracket,
let me know, just pay shiping
Lucky you caught it before you finished the conversion.
I could use the idler arm bracket if you still have it.
PM sent
I'm lazy... gonna take the easy way out>> replace it
Rather help a member in need
Idler Arm Bracket is taking a trip to see New York :D
now, if I can direct the steering box mount into someone else hand
that would be great
At least its only a slant 6 frame, easy and cheap to find, I've got a spare if you need it. :burnout:
