Started this project almost three months ago and was finally able to get the rear end back together again. While the rear end was out, I decided to replace all the lug nuts and washers. Tried to order some off the net but could not find any that would fit small bolt pattern Cragar S/S wheels. Went to several places here in Houston, but no one had them. The last wheel shop I went to suggested I go to Discount Tire. So, after weeks of searching the net and going from parts house to parts house I wound up going to the Discount Tire about three miles from my home and ordered the lug nuts I needed.
After installing the rear end, I then had a problem with the new Cragar washers that came with the new lug nuts. Several of the lug nuts did not want to torque down to 60 ft lbs. Instead, the lug nuts continued to turn and eat into the washers. Contacted Cragar and worked with Robert to get problem resolved. Manufacturer was contacted about any reported problems with the washers, and none had been received. I was asked to send the washers to Cragar so they could try to find what was wrong. Robert sent replacement lug nuts and washers for all of the ones I had purchased through Discount Tire. Installed the replacement washers and lug nuts without any issues. Have not heard back from Cragar yet about what they found problem was.
So now after months of problems everything is back together again, and a test drive was done Friday. Pleased to say that there is no noise! Do not know what caused the noise, perhaps the diff just needed to be cleaned and some fresh oil. Just don't know, but for now all is good.
