Ground wire location for 71' Demon turn signal /park lamps
ricomondo
Lake County, IN
I had to replace the pigtail connectors for both front turn signals on my 71 Demon.
Both of the separate ground wires were missing on the old ones.
I'm not seeing where the ground wire with the eyelet grounds to for the new connectors.
I just did not want to drill a hole and screw it into somewhere it should not be as I'm trying to keep it looking factory.
Looking to see where it screws to please and thank you!
I thought those grounded through their pigtail connector to the front end harness, and then teed into to the headlight ground wire.
Driver's side attaches to the body ground with the negative battery term. Pass side, should be a hole in front of the horn location on the radiator support.
